Jordan_TCFD
I am working on adding stuff to our command trailer. I know what I'm doing about lights,radios and batteries. My next project on the trailer is adding a vent fan through the roof. I am bidding on a RV/trailer retractable vent on Ebay that has a 12 volt fan. What I need help on is putting a thermostat on it so it doesn't run all the time. I'm looking for it to run when the inside temp gets above 80-90 degrees. I found this on Amazon, but the temp is higher than I want, but the price is right for me.
Amazon.com: Hayden Automotive 3653 Economy Adjustable Thermostatic Fan Control: Automotive
We had the trailer pulled out the other day, I opened it up after it sitting for a few hours, to try to work inside and it was completely unbearable. It was atleast 20 degrees hotter than outside(It was already hot anyway). This was expected condition, but it got me thinking of putting a small fan through the roof to at least try to keep it a little cooler. Even sitting inside the building it gets a little warmer, so I know this would help.
What would be the simplest, easiest thing to do? The way we have it wired, I have a battery in the tool box, with a trickle charger. The trailer is wired for 110 A/C with a plug outside where the generator is hooked up. When at the hall is plugged up to the building as there is a refrigerator inside with drinks and such.
Thanks for the help.
Jordan,TCFD
Jordan,TCFD
