firemedic10584
I have the FHL2-SC universal relay flasher from fed sig installed on a Chevy C5500. I have it wired correctly but this is the issue I have. On the passenger side, when the high beam flashes, so do the low beam which I'm fine with. When it goes to the driver side, the high beam flashes and then it goes back to the low beam. So if you look at it, it's almost like the driver side low and high beam and flashing back and forth. Any thoughts on how to stop this? Or is there a way to make both the low beam and high beam on one side flash then the lights on the other side flash? Does this make sense??
