HHS 3200 issue
ccsd157
43
New Bern, NC
For some reason SL3 turns on the siren, and I cannot find a way to disable it in the software....any ideas?
I want it to turn on the 3rd level of lighting, and use the other programmed buttons for siren activation.
shues
NW Indiana
If your control head is the 3207, page 5 of the manual leads me to believe that this is the default behavior:
To achieve your desired result, I suspect you can select Slide Switch 3 and uncheck the box for Turn On - WAIL. The default must look something like this:
woobatu
