So I'm having trouble figuring this one out....
Here is my current setup:
Basically Buttons currently do as follows:
REA = all rear lights (including HLF)
FRT= all front lights (including TLF)
ALL = all front, rear, and side lights (basically every light on vehicle including HLF & TLF)
A/H = airhorn
WA = wail
YLP = yelp
HLF = HLF
MAN = manual
CUT = the button I'm trying to figure out... I want this one to cut off the HLF and TLF from the REA,FRT,ALL buttons
L-A = Left Arrow (Traffic Adviser)
TD = Takedowns
R-A = Right Arrow (Traffic Adviser)
So as you can see above... I'm trying to have a single button to kill incandescent lights (white) from the REA, FRT, and ALL buttons... I have it currently set to have the correct inputs turned to off when the button is on... but I guess the top buttons are overriding it... (the button has no effect)... The other thing I tried was making that CUT a TLF button and just having the HLF and TLF buttons activated with the FRT and REAR buttons (respectively)... but doing so, the FRT turns on the HLF button when activated but doesn't turn it off....
I'm trying to maintain control so I can have the HLF and TLF be able to be killed so I can run the LEDS for a longer time without the vehicle running (like doing a road extra job....) But I'd still like for them to come on automatically with FRT/REA/ALL and kill automatically with them so I didn't have to press two buttons each time....
I also like being able to have HLF on its own control so I can turn it on without colored LEDs but this isn't an absolute requirement....
Any suggestions (using creative programming... not using relays and extra switches)?
(only other thing I can see short of the above is having a separate HLF, FRONT and REAR LED only buttons probably by moving both T/A functions onto one button)
A/H = airhorn
WA = wail
YLP = yelp
HLF = HLF
MAN = manual
TD = Takedowns
