I've been having this discussion with a few people and I wanted some input. All manufacturers stipulate that using an HLF decreases the lifespan of the bulb being flashed. My question is, how many of you have had to change out a high beam bulb due to using a headlight flasher?
I've been using HLFs since '93 and in the multiple vehicles I've had since then and the hours of usage I've put on my emergency lighs on each vehicle, I have yet-to-date had to ever change a high beam bulb. I have changed more low beam bulbs than anything, but a high beam bulb, I have never.
For those of you that use HLFs, have you ever had to change out a high beam bulb, and in your opinion,was it due to the HLF or normal wear and tear?
Tony
Tony
