Impala problem
Hoff
892
SW Ohio/US
Don't know if this is the right section, Mods feel free to move as needed.
Ok so my section's 2008 9C1 Impala is making a farily rapid clicking sound when you open doors, operate HVAC, and now it does it by itself when car is off and secure. It also makes a louder similar clicking sound when you first start the car and start to drive. The clicking will stop on its own and used to stop when you would switch the HVAC setting from "outside air" to the "inside air". The clicking seems to be originating from the passenger side of the console deep under the dash. Wondering if anyone has had this problem or heard of it and if anyone has any ideas on what it is. Thanks.
twodogs603
1,196
Norfolk,VA
I think I may know what it is as my 2003 GMC Sierra did it. I cant think of the name of the part, but it sounds like the piece of the heat/AC vent system that has the door that moves when you switch from vent to floor to defroster-some type of diverter or actuator. When it gets to its final travel, the motor keeps trying to push it farther which it cant. Its not getting the signal to stop. So the motor is turning and some type of mechanism is making the clicking noise. The only thing you mentioned that stumps me is you said it does it when the car is off.
If you can find that unit under the dash, pull the electrical connector from it when its making the clicking sound. If it stops, BINGO.
It may not be this at all, but it sounds a lot like the problem I had.
partss11
62
Arizona
My old explorer had a similar problem, ended up being the heat/ac blender box. Pretty cheap repair if that's what it is.
J. Forbes
164
Houston
We worked on an Impala about two weeks ago that did the same thing. Kind of sounded like a relay clicking constantly, but a lot louder. Drove me crazy. The owner said "it just does that".
ryanm
587
Arkansas
The "blend door" or some such IIRC. It's annoying.
Hoff
892
SW Ohio/US
That's what me and another handler had postulated. Hopefully it's a quick fix for the dealer (we aren't allowed to fix it).
NVFD612
167
Indiana
Hoff,
We had the same issues with some of our AF Wimpalas. To include when it was off... It is something with the HVAC and the dealer was able to fix quickly. They seemed to know exactly what it was as soon as I pulled in (I was the VCNCO at the time). It would appear this is an on going issue . Best of luck, I know how sometimes the Kennels seems to get forgotten until there is a bomb threat or OSI has a drug bust they need help on...
Dennis
resQyou
rick h.
Green Bank WV.
You need to remove the glove box by pressing down on the back of the tray .You will notice a black valve with a couple of hoses .Start your vehicle and hold your hand against the valve and you will feel the clicking . Cost Me about 70.00 parts and labor to replace the valve a couple of weeks ago on my 08 impala . It is called a fresh air actuator . It is a pain to get to the screws to change out
Hoff
892
SW Ohio/US
Thank you guys, I'll give the VCNCO very specific details about it and hope they take care of it quickly.
GSPS629
