Wanted Indianapolis Police XL lightbar
Mark1710
35
Ohio
I am looking for an Indianapolis style XL lightbar. Ive attached a photo of one for a reference. Its a 48" bar with a red lens on the driver side and a blue lens on the passenger side. There is a clear cut out in the middle of both lenses for take down lights. The end caps are also clear. This bar also has 4 rotators, 2 alleys and 2 rear flashers.
Reactions: Jesse J Volanti
Jun 18, 2013
3,718
PA
Mark1710
35
Ohio
It seems those were the mounting brackets they used on many of their cars. Heres a newer caprice with an xl bar and same brackets.
Mark1710
35
Ohio
You have to admit that those stainless steel Aero feet are better than any of Code3's
feet. Somebody in that Dept. had a good budget and an eye for quality.
They look good. I like the code 3 brackets too though. Theres at least two different versions of code 3 brackets ive seen. A lower version and a tube type
Jun 18, 2013
3,718
PA
Yes and No.. The code 3 SD and XL feet are tube style feet as well. There were the permanent mount tube feet, and the extended style tube feet. I can't comment on anything newer but they did the job.
jriccio@necommunications.
