Henry455 said:That the 16 port version of the Mdl 28. twice the pitch of a standard 28. Although less common then the 28 I would not call them extremely rare. They show up on Ebay from time to time. As far as cleaning up, just old time elbow grease. I usually use paint stripper on the front grill (it is brass) and sand the motor and stator after removing the rear brush cover and mount. After sanding with 220-320 grit sand paper, I shoot it with a light coat of primer and then a "hammertone" gray enamel. Most aerosol paint brands have a gray hammertone paint. I have enclosed a picture of a NOS Federal model O with the correct finish and a 28H I had a while back. As far as value, cleaned-up and painted $175.00-225.00 would be my guess.
Wailer said:About as pleasant to listen to as a dentist's drill. They aren't as common as the standard pitch version, so I'd say they are collectible.
Skip Goulet said:I know that you detest the high pitch sirens, but the 28H has always been one of my favorites. When I was a kid (actually I still am at 67), Midland's southside police unit had a 28H underhood. Twice while at a friend's house on the southside, that police unit escorted the ambulance from the small town of Iraan, TX to the Midland ER. That shriek was ear-splitting, and is one of the few underhood sirens I ever heard that could be heard at a distance. The other is the B&M S8B Siro-Drift!
CHIEFOPS said:I agree, the 28H is the perfect car siren while the 28 is a truck siren. I can't explain it.
Dissension said:My speculation has been it's related to the city's noise ordinances, which are the same reason FDNY uses 58-watt speakers.
CHIEFOPS said:Yes, I know most car-chassis ambulance/hearses had 28s, and FDNY apparatus used 28s well into the late 80s. Maybe that's why I identify the 28 as a truck siren. I like them even better than the Q.
In my opinion, the 28H is a car siren, it just sounds to me like it should be on a car.
Skip Goulet said:He stopped at all the red lights and looked to make sure no one was coming and then went on through. That was an experience!
NPS Ranger said:That was good driving.
Wailer said:So what you're saying is that you like high-pitched sirens for small vehicles and low-pitched sirens for big vehicles.
I don't like high-pitched sirens for any vehicle, big or small. Loud high-pitched noises will cause permanent hearing loss.
CHIEFOPS said:I can't explain it, it just seems right to me, regular-pitched mechanical sirens match trucks, high-pitched mechanical sirens match cars. I've heard just about all of them, including Federal's volunteer line, the only mechanical sirens that sound appropriate on cars are the 28H and the Screaming Eagle.
