Installers recomendations for Power Distribution...
G1159
184
0
Southern New England
Looking for some of your favorite products for power distribution.
Large guage power wire Split to two 8 guage power inputs to Whelen HHS. 30 amp relays for front and rear warning groups from two 10 amp assignable outputs on HHS. Also splitting out for a group of radios and other various accessories.
Any ideas for Ways to do Power Distribution?
For grille, dominator, and fog light LEDs, just split it under hood or run seperate zips for each from the 30 amp relay for front?
Looking for best practices and to trigger some good discussion.
Thanks.
Are you going to be exceeding the 10 amp output of the swtiches? Is that the reasoning behind the relays? You may not need to run the full power to the switch portion of the HHS if you are going to be using draw far below the max.
BlueOrange
