Rhinojoe said:Anyone run a upfitted loom thru the GM Truck towing mirrors without any binding/kinks when the mirror extends and retracts?
I'm figuring using black wire loom with a few spriral loops, enough to extend and retract.
Thoughts/Ideas?
Thanks
RJ
WIRED HDH said:we did it, kinda a pain and we had to really work to not have the wires bind up. If i remember right, we could not have loom running through the arm, we had to tape it as tight as possible. On that note thought, we were able to get 4 18 gauge wires through and to the light.
MESDA6 said:Just thinking about some other things I've used loom on, the ridges of the loom may bind up. You might need to use some small diameter vacuum line or fuel line over the loom so that you have a smooth surface that the mirror won't bind on. Heat shrink might work also.
bigcat said:Have you popped the mirror section off yet? Just mimic what the factory wiring is doing behind the mirror and it'll work fine. No loom either. I would use protected wiring like strobe cable (as a widely known example). Something in a casing that is smooth on the outside and flexible. You'll see how simplistic the oem wiring is when you get in there.
Lighten said:Strobe cable works the best for mirror installs, thats what i use for them. The GM tow mirrors are prolly the most aggravating to put a light in also super duty mirrors are close behind.
