aacosta367
unlisted said:900 series smart led from Whelen. That would be the best intersection light- make sure you don't put it on split fail.
Dodge Ram 1500 and try to keep my light hiddenefdny2003 said:I would have to second acala91, if your just asking in general or asking for a specific truck. If for a specific truck what make/model, and how are you willing to mount them ie: do you have a brush guard, intersection bracket, body mount, whether or not you want them completely hidden or don't care. I personally have Whelen Tir3s mounted on my front bumper for intersection, which seem to work fine for me; but I also have a Hyundai Elantra not a truck.
aacosta367 said:Dodge Ram 1500 and try to keep my light hidden
Eric1249 said:I posted a simular topic. So all clear is the best way to go? ION or M2? Sorry for hi-jacking post
acala91 said:My problem with clear is that, while being attention getting, is not associated with emergency services. If only that light is visible it won't stop traffic like a flashing red would. In my opinion, if you want clear to the side it needs to be with a dual color light that flashes red and clear. If a dual color light is not possible, then solid red.
PJD642 said:Generic recommendation: something white, as far forward as possible. I've got Tomar RECT-14s mounted horizontally along the bottom edge of the headlamp housings on my Explorer. Used 3M double sided tape to hold 'em in place, ran the wires between the housing and the body. The truck is silver so they blend in fairly well.
Storm4200 said:i'm currently using TOMAR RECT14s as intersection warning. I was considering switching to the M2s, or M4s. Now im thinking about trying the new Whelen V-Series for the sides. I guess i could wire the 'puddle-light' feature to come on when i open the doors? Any thoughts ?
picone239 said:You have a picture of that you'd care to share?
Eric1249 said:So what would be a better choice, ION or M2?
Storm4200 said:Ok Eric, go with the m2s and I'll go with the M4s.
acala91 said::no:
Friends don't let friends buy split lights!
Storm4200 said:I like dual colors for intersection lights. So long as they are synced properly, and have a decent pattern.
acala91 said:I like dual colors too, but in a true dual color light not a split light. I believe that an intersection light should be set to a faster attention getting pattern and fast pattern + split color light = split fail.
acala91 said:I suppose it wouldn't be THAT bad, but I'm still not a fan of it because there is't any significant off time. Buuuuttttt, now that I think about it, if you're dead set on clear up front, why don't you go with some 400 series LIN12s split red/clear? They wouldn't be that much more money and would give you a lot better off axis output than the TIR M2s and a bigger foot print. They should fit no problem.
acala91 said:Nope, compare here. M2s on the bumper sides and LIN12s on the front of the push bar.
Wattco - Brent said:
Storm4200 said:now the grill lights in that video are split FAIL. Same color flashing split = steady burn from 100'
i do like the idea of LIN12 400s in R/w.
btw........SYNC SYNC SYNC
Eric1249 said:A local shop that sells Whelen has the M2 in stock, but they are red/clear. Do I or don't I?
StEaLtH2 said:I would do it R/C if it were mine....but as stated, the pattern needs to be right.... SigAlert or dbl flash..
Just .02 on the pile....
