Irish Whelen Justice Wecan programming help
bear2989
1
Ireland
Hi everyone. Geoff from Ireland. I need some help with a 44” Wecan Justice bar I have on my fire dept response car.
My vehicle has numerous other grille, side and rear light heads, all controlled by a 6 button MSC mini controller from Standby Group UK. The controller allows me to use a single button for 999 / Arrival and Reset.
When supplied, the light bar came with a default pattern installed. I was able to change this using whelens software to something a little more attention grabbing. Additionally I was able to change the function of “rear red” button to a slow flash pattern for when “on scene”. This rear red is activated when arrival mode is selected.
Can anyone help me with activating a feature that dims the bar in darkness? In my haste to install a new pattern I’ve somehow lost the dim feature. I’d also appreciate if anyone can tell me if there any DVI style patterns I can apply using the software. The one I have set up currently is a slow style wigwag from the drop down menu. Apologies I cannot remember the pattern name.
Any help would be greatly appreciated. I should be able to send the computer file if anyone needs it.
Thank you in advance
Bpems597
