Jeep Cherokee Pov
cbpdogboy
Veteran Member
1,285
Detroit, MI
I think the front lighting would be more effective with solid flasing instead of split fail. I like the use of the roof rack mounted leds to the rear. More people should take advantage of this location instead of wasting warning output behind tinted glass...imo.
Sync the front lights as well...
I don't know if I like the 3 surface mounted lights on the rear. Again, maybe the would be more effective if solid patterns...
the front LED's in the grill did not look right when they were installed vertically so we went with the horizontal approach to complement the whelen TIR's in the foglight mounts as well as the star mini phantom in the windshield. Since this video has been posted, three more Code 3 gen three TIR 6 LED heads were mounted together and installed in the inside top of the windshield on the passenger side as well as an arrow stick being added inside the rear window. Thank you for the complement about the roof rack, wasnt sure about thaty ideabut decided to go with it. Any other questions, please feel free to ask.
Grille lights should be vertical, larger footprint, either flush with the grille, or installed behind it.
He removed the fog lights and put a LIN3 style light in there? Fail. PAR36 FTW.
Is that a white/white dashlight? Why is there a sea of white and only one red light?
I just don't like the single light up on the roof rack.
Split flash fail.
Arlint3118
