Does anyone know if a Justice JE2NFPA has the ability to change patterns? Model # inside the lightbar is 86119-01. Currently it is set to a random pattern that cycles through 5-6 patterns.
Thanks for help in advance.
There is a 3-wire Scan-Lock cable that is used to change the flash pattern on a Towman's Liberty, so I presume that the same can be accomplished on by opening up your JE2NFPA and connecting the right pin on the flasher to +12vDC.
