Tony63031
When our blue series 400 LED heads arrive. I'll be putting them in and was wondering how to change the pattern in the bar?
twodogs603 said:Of all the Freedom bars Ive installed (which is in the 100's), you activate whichever pair of lightheads you to want to change, and then momentarily apply 12v to the white wire w/ purple stripe. That will advance it to the next pattern. Keep doing that until you find the pattern you want.
Yup, that's why I didn't specify. Get the proper info so you don't cook something. :sadcry:shues said:Be careful! The white/violet wire is not always the the scan-lock pattern wire.
On the Whelen NFPA Mini-Freedom, the white/violet wire is the control wire for the endcap leds. The scan-lock wire is black/yellow in this configuration. More information is here: http://www.whelen.com/install/137/13781.pdf
