julietbravosierra
Hello all, Well I have been tasked with designing a basic, yet very effective lighting package for a grader... yes, a 17 ton champion grader. The grader is used by a state ATV club for trail grading. The trail that is graded is mostly straight (just slight curves pretty much) BUT there are several ( about 6 or 7 come to mind) road crossings. I pretty much have an idea in mind of what I want to do, but i wanted to get some more opinions. Anything will be a step up from the bubble gum machine you see on top LOL.
So keeping in mind that this machine needs to be seen from a long ways away, and must have good side warning, I wasnt sure yes mini bar, or no mini bar. I'm planning on using all my own products. most likely the 6LED surface mount light. but since I don't have all my products available yet, since im finishing up my website, If you just tell me what you think would be appropriate, I'll use my equivalent. If absolutely necessary, I can use SOS, whelen, or federal signal as well. Here are some pics of the actual grader, and the side view isnt the actual grader, but its set up the same way. Thanks for your help!
