Tango7
Does anyone happen to have an internal control board/module from a Whelen TADF6 or 8 floating around? I believe it's called "Assembly, flasher, Duo TA" using p/n 01-0286753-00. That series didn't require the TADCTL1 or TACTL5 controller to work, instead using power to different trigger wires to activate L arrow, R arrow and warning modes.
Trying to set up something that doesn't require the 9-pin setup and controller for a fun item, not for actual use, so I'm trying to do it on the cheap. It doesn't have to be that particular brand or item, anything in a similar vein would work for this purpose.
Thanks!
Thanks!
