So I'm being issued a new truck at work. It's a type 1 ambulance with a referb Wheeled Coach box on a 2015 Chevy Silverado 3500 chassis. The new style Chevy is great, love the truck but the lighting is a hot mess and that's where I need help. Let me preface this with none of the equipment can be changed and nothing can be added or removed. Unfortunately. Also, I had no say in any of the equipment, if I did I would not be making this thread.
Now, the truck has the following lighting and everything is Whelen. All of the lenses are clear.
On the front of the box is five LED 900s set up as R / RW / W / RW / R.
The grill lights are 500 series 5mm. Intersection is a LINZ6.
The sides of the box are two 900s solid red.
The rear has five 900s. The top corners are solid red with a solid amber in between. Then there are two lower level 900s on either side of the rear doors that are split red and white. Yes, there are two R/W 900s to the rear. I know.
Now to make matters worse, all of the 900s are set to seizure inducing single flash 300. The grill and intersection lights are on signal alert.
Now my question to you guys is, how can I make this crap slightly less crappy? The truck looks like a flickering, pink blob as is and the flash patterns are so fast they are actually disorienting.
I'm open to suggestions.
