maratrac help
Dave
bath ny
I have a motorola maratrac vhf high band that i had our county program and it will not scan. i have pressed the scan button untill it beeps and scrolled through the avail channels and still nothing it is set up just like my lowband maratrac. is this a programming issue? or something i can do with out spending alot of money?
thanks in advance
Dave
sounds like a programming issue,that or somehow the scan feature was locked out.
Can you "field program" the scan lists? I know I can on my astro spectras and xts2500's....
Is your mic clip grounded? Maratracs must have a grounded mic clip for the PL decoder/scan functions to work. If not, it will not scan nor will the scan function work while the mic is out of the clip.
Hope this helps,
Chris.
how do i "field program"?
Hope this helps,
Chris.
i have the mic in the clip all the tim unless im talking on it.
unlisted said:
Dunno about scan programming a maratrac but google does:
http://www.repeater-builder.com/maxtrac ... -300um.pdf
http://www.repeater-builder.com/motorol ... op-man.pdf
Hope this helps.
Also, make sure your mic clip is all metal, and contacts both the metal points on the back of the mic (mic hangup part)
Don't some radios need an actual wire to the vehicle ground from the mic clip. Some of our old low band Motos needed this to engage the PL while the mic was hung up..
well i have a low band maratrac next to the high band and the mic clips are mounted to the same surface. swaping cotrol heads does nothing either.
T.Simmons
