master switch, how big??
FiremanMatt3
Junior Member
10
I want to hook up a master switch in my vehicle. My question is how big the switch needs to be rated for, and what online stores carries it?
I have:
-90wat strobe kit
-6 led body mounts, 3 watts each believe (each light has 3 leds gen 2 leds in it)
-1 talon mini phantom windshield led
-2 led grill mounts, 6 watts each (6 leds on each light)
-1 whelen headlight flasher
will a 40 amp switch handle this load? what other specifications on the switch do i need to be aware of?
FWIW i want an illuminated rocker switch. who sells those online in this size?
thanks
might be better to wire everything up to a relay. then use a second power source on the "master switch" for it to kick the rest of the power on for your equipment.
If you didnt want a switch inside the vehicle a closeable circuit breaker under the hood would act as a "master switch"
A 40 amp switch will be fine but as Jarred said a relay would be much better. You could not only use any switch you want but I would think it would cut down on your wire size as well.
Ziva
