JohnMarcson said:There are some cases where this can be a problem. At one point federal strobe stuff had the wires in a different order in the amp plugs. You had to swap the position of the black and the red.....
jdh said:I have in the past had an issue with some code 3 tubes (light bar heads) on a whelen pack.
jdh said:What Pimp is saying is that on some strobe packs you can not mix linear and helix heads together. But that ONLY applys to unregulated suppys. I believe only whelen light bar supplys fall into this category, because I have mixed heads on code 3 and tomar lightbar power supply's with no output issues.
07GD SFD said:Ah, I suppose I should have clarified. I'm speaking solely of hideaway kits.
