Molex connectors on Sapphire
WhelenNDealin
576
222
Ontario, Canada
What models of Molex connectors are used on Sapphire systems? I'm just using it for display/bench testing purposes. I have a brain but no cables. I think that I could just use female connectors for the main power and 20A and 40A outputs, but the issue is which connector types are used for the 10A outputs and especially the system I/O.
Besides the TA connector, did Whelen use an uncommon connector or are they easy to find and I could rig up my own with some of the right pins?
If the connectors are tricky to find, are there any workaround solutions for this? I'm mostly interested in the siren speaker outputs and a couple of specific inputs.
Thanks!
This might help you out. I believe its a kit of connectors but I also see part numbers on it as well that may correspond to the molex part number if you only need certain ones.
Reactions: WhelenNDealin
That helps me out alot too thanks
Reactions: FusionWolf
Brian_antrican
