Looking for a Motorola HHCH W3 with the Y cable, used is fine just needs to work great.
hawkspringsfire Member May 16, 2010 2,340 Torrington, WY Jul 29, 2015 #1 Looking for a Motorola HHCH W3 with the Y cable, used is fine just needs to work great. Last edited by a moderator: Oct 17, 2015
hawkspringsfire Member May 16, 2010 2,340 Torrington, WY Mar 21, 2016 #4 Bringing this back. Still looking for one with the cable.
C17LVFD Member May 21, 2010 1,539 Harrisburg, PA Mar 21, 2016 #5 Hawk, What type of radio is it on? I used a standard db25 printer extension cable and then used the spectra db15 off the back for ignition and speaker without issue. Sorry I don't have one available for you. Seth
hawkspringsfire Member May 16, 2010 2,340 Torrington, WY Mar 21, 2016 #6 It's for a astro spectra plus.
C17LVFD Member May 21, 2010 1,539 Harrisburg, PA Mar 21, 2016 #7 Might be worth a try depending on the application. Significantly cheaper than the hhch cable Astro spectra and Astro spectra plus are essentially the same with a upgraded vocon on the plus. Seth
hawkspringsfire Member May 16, 2010 2,340 Torrington, WY Mar 26, 2016 #8 Found the HHCH now just looking for a cable. Someone has to have one laying around, need ASAP.
