efdny2003
Before anyone jumps down my throat yes I did use the search button, just looking for a little more towards what I'm using. I currently have a Uniden trunking scanner in my car, with a multi-band antenna(as I monitor a range of frequencies) on a trunk lip mount. I've been tossing around the idea of having an antenna mount drilled into the trunk(done professionally by a shop as I've never messed around with that). So my biggest question is, would having a mount drilled centered in the trunk make that much of a difference versus the mount I have now which is centered but obviously by the rear windshield. Also if it would make enough of a difference to do it, are there different types of mounts or are they pretty universal? I will be keeping the same antenna I have now, just also looking a little more esthetics. Any and all help/advice is greatly appreciated.
