Nolines
You absolutely have to give it to whelen for designing a product that needs programming and addressing in order to work before you even get to wiring the strobes in. If you ever get the chance to read the manuals it doesn't say how you address them when you are hooking them up it just says this address flip these dip switches this pattern. But lo and behold they don't tell you they have to be the same all the way around or it won't work. The mpc01 can't find the isp188c which is going to mimic a blink setup if the address doesn't connect to the bl627 siren. Omg I was pulling my hair trying to figure this thing out and then decided, hey let's put them all on the same address and see what happens. Voila everything talks to everything now, cept I misconnected the cables for the strobes and when I hit the buttons or slide switch I programmed it was wrong.... DOH!! but easily resolved with a few mins of unplug and shift while turning on switch and now the whole rear is setup how I like it, cept I'd rather a cometflash pattern over double flash.... Ohh well back to more reading.
