Feeling dumb tonight. I picked up a new power inverter and wanted to check the output Voltage. Probed the outlet with a multi meter set to Vac and got 37. Went and stuck in a home outlet and got the same thing. Took an old appliance cord and tested the leads directly with positive lead to black wire and individually the black wire both from white neutural and green ground with the same result from multiple outlets. AC is not my thing but wanted to make sure both settings and setup were correct as I should be getting 120+/- and not 37.
