Jennifer Rose Towing
One of the places I have less knowledge on is multiple batteries in a setup so I am looking for help. I do understand the systems of a single battery, testing and charging. I do not feel an isolator would be a good fit for what I am looking to do.
The short description is that I want to add a 35 amp hour battery to the vehicle (like a house battery in an RV) and looking for options to charge it.
This is the long version and setup. All of the aftermarket/upfit items I have added to the vehicle have a wiring system that can be isolated from the vehicles battery via a large solenoid. Currently I can power all of the aftermarket stuff via the vehicle charging system or a 110v supply via generator while isolated without issue. What I want to do is add a 35 amp hour battery to power the isolated side when needed without the generator (or vehicle running).
2 main issues are charging the battery and wanting to limit that charge to around 5 amps. I can easily remove the battery to charge it separately but would prefer to find a fairly inexpensive way to charge it from the vehicles charging system while driving (solar is not an option).
The thoughts I have but have not been able to find much on are... Finding some type of charger that runs off 12 volts. I figure if a trailer brake away battery can be charged without a large battery isolation system then I should be able to do exactly the same. I do not believe the smaller batteries are designed to take the higher voltage of a vehicle charging system once topped off. I would think a 2-5 amp battery charger that runs on 12 volts vs 110 would be great. I have been looking a little but have a lot to learn on them.
Seeking input and advice so I can get the system going in the next couple of weeks.
