I had 2 complete Fed Sig Model 14/100 housings and 2 Streethawk rotators. Knowing both use the same motor and the same light module, but a different base.... I got to thinking, "Can I make these fit??"
The answer is............. YES!!!
I first flattened the mounts all the way down, but the motor worm gear wouldn't clear. So, I had to adjust the feet up some. Then there was making the feet meet the mounts. 2 short pieces of steel solved that. Other than these minor changes, everything else is stock.
