Need Assistance_Fedsig switch box
triton911bj
463
Springville, PA
Hey everyone,
We got a SW300 Federal Signal switch box. It is functional, but we want to rearrange it so that it has a master switch, which it does not. How do we accomplish this without purchasing a new box? Any and all assistance is as always helpful. Pics welcome
BJ
All you have to do is hook the output wire for switch one, into the power in for switches 2-6. A word of caution however, do not attempt to run a lot of load through the switch box this way. It is fine for lower amp draw items, but if you are going to be running something more amp hungry through it then get a good 50 or 75 amp relay and let switch one be the trigger to open or close the relay.
Our local SO was trying to run their Excalibur bars all through switch one on the SW300 and ended up frying all the switches. We tried to tell them but they didnt want to listen till it was to late.
thanx! this will help.
we plan on using switch 1 as a master to run 2 strobe packs, a head light flasher and a dual dashking..so i hope we dont have an issue.
Thanx again BJ
Thanx again BJ
The strobe lights and head light flasher should have their own power and ground wires so all you will be running through the switch box is the trigger to tell them to turn on. That and the dash king and you should be fine.
MPD 818 said:
The strobe lights and head light flasher should have their own power and ground wires so all you will be running through the switch box is the trigger to tell them to turn on. That and the dash king and you should be fine.[/quote:w4fm6rt5]
yes, we have the triggers run and set..need to run the power back to the supplies..the HLF is set as well.
Simply have the first switch trigger a high amp relay that powers the others.
OK so the master switch redo now works. BUT i ran into a different snag...when the master switch is switched to on, it works but the back lighting shuts off?? and then the switches dont lite but the do work? tritonboulder47 did the research on the switches and they are wired correctly...so its now at the point of WTF!?
any ideas???
BJ
backlighting power should be independant of main power. maybe that wire got hooked up to #1 too?
thanx for the imput but you way disregaurd!...apperently of course it turns out to be a damn ground issue. somthing simple and overlooked
my bad
BJ
AudioRhino
