Need help installing 3 power outlets
That wire is fused at 20amps.If you want to get power from inside the car,I suggest using one of the supplied 50amp power wires in one of the distribution plugs provided,and fusing each plug seperately.JMHO.
That was my next question. I was thinking the amperage would not be high enough from that one outlet. I think I'll supply a line from one of those dist. plugs to a small fuse block and go from there.
TNConstable
