Hello, I'm new here, been reading threads on this site for a few weeks now, and I need some help installing my older Whelen TA836A directional light bar. I have it mounted, and the harness from the switch to the light bar wired up.
The area where I am having problems is with the wiring from the strobe power source to the truck, and wiring the switch box to the truck as well. I should probably mention the bar has 2 strobe lights in the corners. Do I need a extra switch to wire into the strobe power to run the strobe lights?
My last and final question is also with the wiring. The wiring I have cut off the spool has 3 wires in it, black white and red. I have connections for red and black for the strobe power, and all three colors coming from the switch box. What do I do with the white wire?
Thank you in advance for your help. I greatly appreciate it.
