tacomabanga19861986
we have a rescue truck that is a freightliner fl80 i think is the model
for some reason we cant figure out why the tail lights dont work
ive went through all the fuses on the passenger side fuse panel
either there is another fuse panel somewhere else, or a wire has be cut and it would be a pain in the u know what to find where its cut at
we've checked the bulbs and there fine, i even checked the tail light wire with a test light and no voltage is going to it at all
its kind of a major issue due to most of our calls are at either dusk, nighttime, or when we clear scene its dark out and theres no tail lights to the rear of the truck
brake lights work fine, just the tail light section of it doesn't work
i have looked all i can on google for a wireing schematic for this truck and couldn't find anything remotely close to it
i would be more than happy if anyone could help with this due to it being a safty hazard, and its 2nd out truck to a car wreck
im pretty good with electrical stuff so if someone told me how to do it, or go about fixing it, im sure it will get done
if it comes down to it i might have to run a new wire from front of truck off side markers and "tie in" to the wires in the back and terminate the other ends of wires
i hope this is readable enough to figure out my problem, and i do appreciate any help in resolving this problem
