Need help with my JetSonic
Wow...
Um I'd start with checking:
Ground
Gears
Bulbs
Chain
check all your wires and connections to make sure something isint grounding
Check the gears to see if all the teeth are okay
replace non working bulbs with working to see if its the bulb or the connection
check the tension on the gear chain
Mine has that problem with one rotator, the bushing in the idler gears wear down, making the rotator gear not always mesh with the others. I tried building up the pin that the gear rotates with with jb weld so its not so loose and theres not as much play in the gear
try moving the gear closer, same happened with my J-cal. Maybe you have the lights on front cut-off, thats why the rear rotors are lit.
T.Simmons
