NForce Interior Light Bar Sync with MPowers
tuckerm
444
38
Wisconsin
Can the NForce Interior Light Bar sync with mPowers? It looks like this wire makes it seem possible: Pin 24 Light Green/White Future use - Sync 2.
Anyone know?
Look at the wireing code for your Mpowers and the same for the breakout box for your bar there should be a sync wire or pair of wires you can connect up to each other that should allow them to sync up
You can connect without nuking your heads they aren't power they are data only the heads might steady burn (patturn freeze) till you unhook them at the worst i personally never seen a sync wire kill any head or flasher unless power is applied to it just read the manuals incase there's a need to set anything as a slave and master (federal signal and feniex are 2 brands i know that are configured this way)
I'm trying to find amber/white Mpowers myself if I get them before you solve this issue ill test out the sync for ya
LAXX
