? on single Talon
A-TAD
5
South Eastern PA
What size lighthead does the Whelen single Talon use? Is it a 500 series, larger or smaller?
Also is the flasher built into the lighthead or does it plug into it?
If someone has a picture of one taken apart that would help too!
I saw the picture in the install guide but it didn't answer all my questions.
Thanks, A-tad
911 said:
its not a 500 series head !!! they will not swap !!!
True. They're roughly the same size, but not interchangable.
Thanks for the picture.
I am thinking of buying a few split color single Talons.
As long as the size of the lighthead is close to a 500 size it will work for my application.
I am trying to figure out if I can take off the flasher board and hook up each color to its own flasher so I can turn on each color separately.
It sounds like I may not be able to since there are pins that go from the flasher into the led board.
JP15559
