dmitry103
Knock yourself out...went into effect as of yesterday.
Approval Needed to Use Emergency Lights and Sirens | NBC 10 Philadelphia
K9Vic said:This does not apply to the fire department, they will always go code unless the dispatcher says not too due to minor calls or callers request.
delcofirecop said:oh not to mention they can no longer block highways with police cars they must deactivate emergency light once the vehicle they are trying to stop is stopped they have to get approval to chase a suspect on foot also there is now a limit on how many officers can respond lights and sirens to an assist officer call shots fired is no longer a priorty call unless they have a confirmed visible victim. oh and for those thinking the police dispatchers have enough common sense to decide when it's a true emergency phila pd dispatchers are mostly civilian employes with one or two police officer supervisors in the radio room.
calebsheltonmed23 said:The EMS agency I work for use NAEMD protocols, and Pri. 1 is C3, and everything else is a cold run, period, unless advised otherwise. We can run hot from the scene if we need too though. Apparently, it reduces the whole "it's their emergency so we'll treat it like one" thing. If dispatch thinks it's BS, we run cold basically.
BigWil said:If they are concerned about light and siren use, they really need to revamp the policy...don't make them ask permission, set up guidelines as to when you can respond with lights and siren. I just rewrote our SOPs on them.
Code 1 - routine response, no l&s, used on any call for service that isn't time sensitive or life threatening, respond obeying traffic laws.
Code 2 - lights and siren, not to exceed speed limit by more than 20km/h, used for urgent but not life threatening calls, such as traffic accident without injuries, where vehicles are blocking traffic
Code 3 - lights and siren, drive with due regard, for life threatening calls.
This is an over simplification, but with this in place, the guy in the cruiser decides what level of response they want to use, but they must be able to articulate, by policy, as to why they choose the level they did. That, combined with in-car cameras recording all the time, Philly would be able to deal with the officers who are violating policy, without adding BS to initial call information.
CHIEFOPS said:Even simpler, all the agency call types can be catergorized into the guidelines stated above, the call type as determined by the 911 operator or the dispatcher determines the response code.
BigWil said:My dispatchers are not trained well enough to do that. Onus falls on the patrol person to justify the level of response, based on information received.
patrol530 said:FHP activates the lights, the laptop will prompt them to select a reason from a menu.
crescentstar69 said:So they have to pay more attention to a computer screen than their driving?
