pic request of switch setups
b1gb0y
Newbie
6
0
Michigan
i would like to see how you guys mounted your swithes in your povs... preferably ones the have floor mounted shifters
if any of you have pics of a pov third gen cavalier those would help to
Custom switch panel for 2011 Sienna. Whelen Duel siren , 1510 Grover Air Horn and lights
Custom Switch panel for 2010 Sienna.
Cencom in roof.
If you haven't seen this yet, Look at it. It is our new switch panel system. It requires no depth to mount, is water proof, chemical resitant, and programmable. plus nothing to break off when you hit it with your knee... :)
First: Rear
Second: Grille/Front HAW
Third: Dash
Fourth: "Extra" not connected to anything, this way it's there if I ever want to use it.
thanks guys
i have a spot already picked out just wanted to see some other spots that might change my mind..
63truck23engine said:
Here is my switch set up if you have space below your head unit you could put your switches there.
This is one of the best switchboxes I have ever owned!
I love it. its so easy to use and set up. and were i have it mounted when i flip my head unit face plate down you cant see it
Me likey!!!!
Heres how I had me Galls XL200 mounted in my '95 Tahoe... It fit nicely into the overhead console, and I secured it with some wire on the back side...
sorry for the shitty pic...
FireEMSPolice said:
Wow! Where did he get that?
A friend of mine on the Avanalche forum makes them... BUt last I heard he stopped making them cause he doesn't have the time anymore with his new job... Which sucks cause I was going to designe one fairly soon... LOL
Basically, its a sheet of 1/8" plexy that has a black coating on the one side. Then he has a plotting/engraving machine that does the designs, labels, and mount points for switches...
i had one of those flat touch ones i bought at auto zone for 20 bucks did a good job until my truck was involed in a roll over and i lost it lol
those switches are pretty neat and i use those a lot too!
I am not going to lie, I hate it when people compare ours to the auozone one :duh: :) , Yeah, Kinda similar, but different. Different company, different theory on products. The autozone one is simple, made in china, and with cheap materials thus they can make a 20-30 dollar product. :hopeless: But I guess if you like that one, You will love ours! and if you have had bad luck with the autozone one, don't relate it to ours, :nono: they are not built equal.
We had planned ours to withstand a bit more abuse:bonk:
Ours is built in the USA with materials that are much high quality then the autozone one. It is water proof (both the keypad and controller), UV resistant, Has indicators above the switch,is made with steel domes for the switch instead of an air pocket, Comes with 600 legends, an installation kit, is programmable, has auto current limiting, Low voltage protection, AUX inputs, much better connection between the keypad and controller, etc, etc, etc.... Of course this makes it a much higher cost, but we don't like producing crap stuff...
so yes they are similar, but way different! :) :crazy:
If you want the real thing, Get the WIRED HDH one. :)
I don't know why i used so many Smilies, Just felt right at the time :dielaugh:
Patrick
Here is mine, in a dodge ram.
Where I mounted my siren-
My grille lights-
And my light bar controller is above my rearview mirror.
This is where i mounted my Galls XL400 switchbox in my 94 Ranger. There really aren't many places for mounting in it.... so i ended up making my own mount. I got a project box from radioshack, and hid all of the wires (THERE ARE A TON) in there... and mounted it directly to that. Did the best i could to "hide" all my wires with the cover's, but dosent look nearly as good as the ones above. My problem was running all my positives and negatives and hiding those wires....
Well i'll add my two rides since i know how to do this pic from phone to PC thing...
i took these pics last night so they arent that great. Ill take day time pics when it gets warmer.
This is in my 93 F150. This is where the lil cubby hole used to be. This is a 6 gang switch panel i bought from J C Whitney many moons ago in the RV section. Unfortunately these panels are no longer available in the 6 gang selection just 2 and 4 now.
[Broken External Image]:http://img.photobucket.com/albums/v689/military_dude69/0202112308.jpg
In order.
1. a set of driving lights under the rear bumper as back up lights
2. scanner
3. front driving lights
4. back lighting for sw300 in havis consolidator (its what the cb is mounted to in 1st pic)
5. HLF trigger
6. open. (I've owned to of this panels and they both seem to have this switch as a "momentary" switch they never latch all the way on.
[Broken External Image]:http://img.photobucket.com/albums/v689/military_dude69/0202112307.jpg
Now the Kia.
for these two switches i took out the tabs in the dash that are removable and had the switches moutned in those panels that way i dont have to replace the dash if i sell the carand i dont have to rip the dash apart to get to the switches i just re pop the panels back out.(much easier to do)
This switch is on left side of steering wheel, its for my dash light.
This switch is in an oval popout tab that im guessing where the original switch would have been for the foglights from where this vehicle is based out of. it actualy has 2 real switches that look similar to this one in the center of the dash. 1 for rear defrost and 1 for hazard lights)
I apologize for the dirty car and poor quality images. It snowed more than a foot the other day and well, I don't feel like cleaning out the car with more snow on the way. It's a '02 Cavalier. The switch box is home made from radio shack. This car is just a get-through-the-next-year car, so I'm not too heavily invested in the install. My next vehicle will have a much nicer set up.
06 Charger R/T. There is a small, useless cubbyhole on the dash in the no NAV radio models. I fabbed up a custom switchplate for it.
Blade Runner said:
Where'd you get that switch panel? That's badass!!
Billet Technology. They make a lot for Chrysler products. http://www.billettechnology.com/
Buy the switches, draw it out with any engraving you want, and mail it to 'em. I traced the outline of that storage pocket onto a piece of card stock. I laid out the switches how I wanted 'em and even made the cut outs. That way, I knew it would fit into the area. Mailed it all to 'em and a month or so later (I mailed it the week before Thanksgiving, so the holidays delayed it a little) I got it back. It comes with 3M double sided tape on the back.
2008 Ford Fusion
Red Switch is for my siren (wail and yelp)
Black switch is a monentary switch for my siren(Air horn and phaser)
Red and bule switch for my light set up
This is a Jottodesk console mounted in my 04 Tahoe. Switches are for Front Led, Rear Led, Strobes, HLF, Siren Power, Then Up/Down switches for mode. I have since changed the bracket for the Middle radio to the correct bracket.
Frank
Frank
Does (or did) your Tahoe have factory-mounted cupholders attached to the front of the OEM console? I've been looking for an equipment console that can be installed in my 2007 GMC Sierra without having to either remove the OEM console or bolting one onto the center hump.
This Jotto Desk console appears to be the solution; however, I cannot tell if it'll clear the OEM cupholders and the mounting plates will work with the OEM console still in place.
They are nice looking switches. Way to much for me to spend on a switch
Brian_antrican
