Pricing question
RL1
Veteran Member
1,655
19
40
Ga
My dept is 100% Whelen right now, but I'm trying to change that. If anyone would be willing, could you give me a very rough estimate of what you (who carry Whelen) would charge for this set up and you (who carry something else) would charge for something comparable. I'm hoping if I go in with some realistic numbers, we can save some money and break the mold since only two depts in the region use something other then W.
Installed on Chargers:
Liberty, fully populated heads with LED TD's and alley's, TA function
6 head dominator (to be attached to push bumper)
4 TIR3's (2 on side of PB, 2 on LP bracket)
Vertex x4 (2 white in headlights, 2 blue in reverse lights)
2 single avengers on rear deck
HLF/TLF
295 series siren
Using mainly Feniex Products; Here is what I came up with
* All Feniex Products use Phillips 4 Watt LED's producing 200 Lumens per LED
Avatar 47" - $1750
- fully populated with LED TD and Alley and TA function
Python 600 - $290 Each
- uses 4-4Watt LED's per pod can be configured in a multitude of ways
- TakeDown Steady
- TakeDown Flashing
- Left, Right and Center out Arrow
Python T4 - $52 Each
- surface mount
LP Bracket - $20 Each
Fairy HAW LED - $60 Each
- 8-4Watt LED
- Surface mount or HAW
- Bezel Included if needed in Black or Chrome
Python 1X - $94 Each
- Comes with a flashback shield
- Mounting options
- Suction Cup mount
- Headliner mount
Sho-me 11.1005 - $45 Each
- Split the rear tail lights and alternate the deck and the outside
- Would not use brake light function
Sho-me 03.W140 - $95 Each
- High Beam override
Whelen 295SLSA6 - $400
- Great siren
- High Current Model
As stated above this totals around $3236 + S/H
If needed
Triton Speaker - $114 Each
AnotherMike
