i am new to the forum an am having trouble understanding how a progressive slide switch box works. Can anyone help me? i need to know how i would wire this type of switch box to my lights. an how to wire the slide switch specifically.
iwillits said:i am new to the forum an am having trouble understanding how a progressive slide switch box works. Can anyone help me? i need to know how i would wire this type of switch box to my lights. an how to wire the slide switch specifically.
charlie82 said:Anyone know where I can buy/make a very low profile slide switch, or use some kind of toggle?
C17LVFD said:Welcome to the board.
A progressive slide switch lets you go from position 1 to 2 to 3 and progressively turns on more lights... A lot of people have them setup as
Position 1: Rear maybe 1 or 2 secondary lights to the front
Position 2: Front and Rear Red/Amber/Blue
Position 3: Front White and HLF
You're going to have to be way more specific with regards on how to wire the switch box to your lights... As a "professional installer" as stated in your profile, you know that you have a designated area whether it's remote from the switchbox or at the switchbox which you bring all your lighting connections to be managed usually through relays.
My recommendations would be decide which slide switch box you want to use, and then read the directions and follow accordingly. If there are still outlying questions, use the search function to see if the same question has already been asked. If it hasn't been asked then obviously ask as the forum is a wealth of knowledge.
The programmable switchboxes such as the CenCom, SmartSiren, Code 3 RLS and others can be challenging to someone who hasn't programmed them before, but for your everyday switchbox with a slide switch and 4 on off switches, the directions are usually quite clear.
iwillits said:fedsig sw400
blue70chevelle said:Building a relay setup is a huge pain in the ass.
shues said:It would be a lot less of a pain in the ass if you weren't building your own jumpers. You could get some jumpers like these:
[Broken External Image]:http://www.kwikwire.com/images/Jumper 2.JPG
They install like this:
[Broken External Image]:http://www.kwikwire.com/images/jumper 3.JPG
