Putting two led haws in the same housing?
Fast LT1
Veteran
2,019
7
Sedgwick County, KS
Has anyone tried putting two led haws in a housing vs just 1? Is the light output worth it? Im thinking about putting two in each of my reverse light housings for an extra pop similar to real strobes! :lol:
The only time I have seen it is when people want dual colors. I know they make split LED inserts, but this way people get full brightness out of each color. I'm sure doing two of the same color would be brighter, but I don't know what it would be compared to "real" strobes. Also, there is the cost benefit ratio to consider...which I'm not sure what it is in this case. Your money might be better spent on a pair of different lightheads to use to make the area more visible. Either way it is your call.
Let me know if you need some Universal Undercovers if you decide to do this.
Thats what i'll most likely be using, unless i can find a good deal on some Axixtech tri's
dlp1684
