Duster
I received two Signalmasters from a friend. Neither have any markings identifying the model.
First one is a halogen 8-light, but the end lights are in red and blue, leading me to believe this is a 6-light with flashing endcaps. When I wired it to a controller (SMC56 or 331112, depending on the age of your box), it functioned as a 6-light with flashing endcaps, so I think I was correct.
Second one is an LED Cuda narrow (modules in landscape) 6-module stick. This one has 3 sections in two different modules (2 in one module, 1 in another) non-functioning; otherwise it is in good condition. I also attached this one to the same controller, and it functions appropriately as well.
I say they functioned appropriately, but there is one problem, which is where my question comes in:
The arrow patterns are reversed!!! I thought maybe it was a wiring problem on the bar (I worked on the halogen first), so I tested the LED as well, and they both do it. The functions all work appropriately, except that the left arrow toggle makes the bar go right, and the right arrow function makes the bar go left. The indicator LEDs on the box show the proper pattern, but the bar is reversed. I thought maybe I had the bar sitting upside down, but the cable is coming out the driver's side, and the halogen has the sunshade, and it can only be "up" in one direction...the red flasher is also on the driver's side, which leads me to believe that I have them orientated correctly.
Since it is happening on both bars, it makes me think it is an issue with the controller. Is this something that is known, and is it something correctable? If not, can I just reverse the order of the wires in the harness to make it work right? I'm just starting to learn about these bars, so I'm not sure about everything yet.
Anyone have any insight or suggestions? I'm willing to just reverse the wiring if that will work, but my curious nature wants to know WHY it is doing this...
David
David
