I had this idea in mind of figuring out a way to run permanent wiring from battery and switches up to my roof. At this point i would like to be able to mount a junction box of sorts to where i can connect all these wires and then all i would have to do is connect in whichever bar i wanted to use for a while from a short wire harness from the bar to the box. Taking into consideration that the bars may require different gauge wires, theoretically couldn't i run the highest gauge wire required for the bars i have and then i would be good for using any of the bars?
For example...let's say I have an Edge 9000, a Vector, an Aerodynic, and a StreetHawk. All basically the same setup. Either Strobes or Rotators with side alleys and front take downs. If i figured up which one needed the heavest wire and ran this from power and stitches to junction on roof, i could then hook in whichever bar i wanted to use at the time?
I have found a couple of watertight marine grade wiring junction boxes, just unsure at this time what gauge wire they are capable of accepting.
Anyone ever been crazy enough to try this? Or any Wiring guru's got any objections to this type setup? Would love any and all feedback.
