Re Broadcast set up NO siren
Abacus
432
Sydney Australia
Can anyone recommend a manufacturer who provides a speaker selection switch for radio broadcast? I am looking to split an UHF radio to either both and/or an incabin communication speaker and an external speaker (not attached to a siren)
Thanks in advance
tvsjr
611
TX
What model of radio? Many offer a built-in PA rebroadcast feature. Spectra/Astro Spectra/XTL/APX does, many Kenwoods can be outfitted with an option board, etc.
JazzDad
5,165
USA
I once used a relay, that when de-energised, switched the audio from the interior speaker to the external. Is that what you are trying to accomplish?
Abacus
432
Sydney Australia
Thanks for your responses
Its an Icom ( probably not common in America) with just one external speaker 3.5m socket
Is it just as simple as putting a 2 way switch between the incab communication speaker and the external speaker which is a Kenwood KES 5
MtnMan
1,533
Eastern PA
Yes, it's that simple.
tvsjr
611
TX
Assuming the internal audio amp has enough drive, and is tolerable of the 11-ohm load of a PA speaker. What's the model number of the radio?
JazzDad
5,165
USA
You may need to put a couple of resistors (voltage divider) on the interior speaker unless you are will to manually adjust the volume each time you switch over.
Abacus
432
Sydney Australia
Thanks for everyone's suggestions. The external socket can drive a 5 watt speaker at 4-8 Ohms. I am going to cut the wires into a switch and give it a go.
I dont need it to be super loud outside just better than leaving the windows down!
GSPS629
