Replacement oscilaser workings
Abacus
432
Sydney Australia
So I am posting here as the halogen Code3 oscilaser is pretty much "old stock" nowadays.
I have just been sent 4 replacement inner modules and of these 3 have a flat tab at the top of the rotator mirror that fit into the bumper mount housing. One has a tab at about 60 degrees. Anyone know why this would be.? Is it a different part maybe for lightbars than for the bumper mount.
Its not an issue as its going into a lightbar but curiosity got the better of me!
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
like the difference in the photos below?
jdh
Geneva, FL
They use the lower module lamps from the MX. They are glare shields to stop the light from illuminating the upper sections/domes when they stopped using the louvers.
Abacus
432
Sydney Australia
Thanks John and JDH
Have to say it is rather fun getting them going again and in a M pattern. We havent used them for years and I found a cheap (ish) US based stockist as well as Britax over here to get me the replacement parts.
jdh
Geneva, FL
dmathieu said:
I always thought that those tabs were heat shields to help keep direct heat from the bulbs from melting the top of the lens/dome.
You could be right with that as well
Abacus said:
Thanks John and JDH
Ya they were prone to breakage
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
lite-em-up said:
Correct. Heat sink/shield
They are often bent up in larger bars, down in lower ceiling mounting locations.
GSPS629
