RX2700 23pin connector issues
Hi all, I'm new to the forum so apologies if I've posted in the wrong place or made a mistake.
Ive just acquired what I believe to be an RX2700 lightbar.
It has a 23 pin circular connector, I'm presuming these are + triggers.
Im not sure what the individual pin configurations are and whether the lightbar is also powered via these pins.
Ill provide an image with this post.
I havent had chance to open the lightbar yet.
Also I'm based in the UK.
Reactions: kitn1mcc
It appears that the connector is one that was installed by the agency that owned the light, these types of connectors arent standard for code 3 lightbars from the factory.
Your best bet is to open the lightbar up and test each pin with a multimeter from the inside of the lightbar to the connector to identify what each pin is.
Thankyou very much for the reply.
I will open the lightbar up shortly and have a look, I'll update this thread with photos outside and inside the bar
sounds good, also try to see on the ends of the lightbar for a model sticker, it would be helpful to know what exactly it is to get the proper manual for it.
Update with photos, its actually a britax?
Ive just opened it up and posted photos, its actually a britax?
Got it working just trying to figure out how it changes patterns
Britax is the European side, or was, of Code 3 Public Safety Equipment. You have quite the mixture of modules in that lightbar. From what I can make out of seeing them from the top down you have the LED-X modules on the 45 degree corners and sides. The (4) right next to the corner modules are the OPTIX-6. Now , those (4) modules facing forward look like the ones that were in the Code 3 2500 series bar. They were dumb heads and needed a flasher to make the lights flash. That quick disconnect was sold by Code 3 and installed either by the factory or customer. I sold a lot of those. the quick disconnect was perfect for my demo vehicle which carried 4-5 different lightbars that disconnect worked on them all. Those that came from Code 3 in the U.S. there wire colors matched the wire colors used in the 22 conductor cables, but I cannot speak for those that were Britax. But that lightbar would be easy to add in a wiring harness if you want to extend that cable.
Cheetah
