Maxim2Eng
Supporting Donor
About a year + ago, I snagged a Dual Comm from a towing company near where I live--it had clear domes and no holes in the speaker cover. The domes were not broken but badly fogged, so much so I didn't notice it was missing a rotator! Oh well, I got it for $25. Oh, and the remaining rotator was missing a motor and mounting bracket. Did I mention it had clear domes?
I started my hunt to find placement part and several eLbers offers--thanks!, but the photos didn't match what I had. Color me puzzled. I was able to secure a two-bulb rotator on eBay recently that matched my cans for a good price, and, although it had obviously been "whacked" by an obstacle, I was able to repair it to near perfect condition.
In my search, and in postings here on eLb, I began to notice there appeared to be differing styles of bulb cans used by Signal Stat over the years--btw, the Signal Stat 350 two beam beacon uses the same rotator as the Dual Comm, but the Gen 2 Dual Comm rotators were "counter rotational" (was Gen 1? Doubt it--see below.).
Generation 1: Solid can; motor mounted in top of can; one power wire to motor (grounded through mount).
Gen 2: Vent holes added; gears moved to base of shaft. Motor gears remain the same, but the motor gearbox output shaft is in a different position/configuration; two wires to motor--power/ground--facilitating counter rotation.
Gen1 on left; Gen 2 right:
Note additional ground brush on shaft.
Gen 3 seems to be supplied by the same manufacturer to Dietz, which had different gears (same gearbox output shaft configuration) and only two "chimney" vent holes in the upper can.
The Dietz bars were very similar, but the domes were sloped on both ends. My mini bar cut was down from a full sized "dumpster" save and the Jefferson Co. (KY) PD cruiser with full sized bar (JCPD also ran the EMS service at first with red/blue lenses on ambulances--they also made traffic stops...that didn't last long).
Gen 4 abandons the "can" and uses a bulb holder system comparable to the FedSig 17X beacons consisting of an upper and lower plate.
So, I need a motor and mount for a Gen 1 rotator. I can fabricate a mounting bracket an use a Gen 2 motor. I've been buying 350s searching for spare parts, and soon, I will have about 6 Dietz rotators available for purchase.
If anyone has a Gen 1/2 Signal Stat spare parts bucket in their workshop, I would like to hear from you.
