PTRJason
So here is the deal. I used a coat hanger and hung a Cuda SignalMaster 6 Lamp, and an 8 Lamp SML-8 LED.
I plan on putting two Cuda single heads on top, or below it for rear flashers. It will be mounted to the rear headliner, where the agency who had my Expedition before had cut the trim and mounted a rear bar. So I will just re use the holes, and not make more.
I took several pics, tell me see what looks better.
I wanted an 8 head Cuda but the OHP bars are cheap so I got one of those, also thinking the rear foam padding will be nice since it sits right over the third row seat.
I have 4 Cuda single heads, and may take the ends off of the two of them, and off of the SM, and then flush mount them together to make the 6 head SM into an 8 head, kind of.
Also since this is also my POV, I want to get a 12 pin AMP connector, and wire the rear bar and flashers through that, as well as use wing nuts to mount the SM to the roof, so IF I ever have to carry 7-8 people, I can just unplug the rear bar and unscrew it and they will have head room.
