SOLDFederal Signal FireBall II Lights/Code 3 3672L4 Light/Pa ControlSOLD
Federal Signal FireBall II " rear deck console ". This console showcases 2 BEAUTIFUL used/like new Federal Fireball 2 B/R Lights with Tri Flash Mirrors and extremely strong magnets, 2 Sho me Par36 alternating B/R alternating Lights powered by a Federal Signal FLH2-SC 12 Volt Headlight Flasher unit. All of these components are in EXCELLENT Condition and are very clean. All lighting equipment has been bench tested and works as it should. The FB2 Lights are whisper quiet! You won't be dissapointed if you are a FFB2 Fenatick. 2 matching power cords with approximately 3 feet in length are included as well.
If this weren't enough, I am adding an Immaculate Code 3 3672L4 Light/Pa Controller unit to this package. This controller is pristine in condition and has a 3 position slide switch with the rubber boot and 4 white push button control switches for more ways to control additional lighting. The Code 3 microphone allows public address via your loudspeaker along with 3 tone settings. This unit will complete this package and offer everything you will need to restore that vintage era correct antique vehicle restoration! All of the above listed items are included in this sale. * * Note, the blue mounting surface is for demonstration purposes only and will not be included in this sale unless you really want it. * *
Asking $325.00 for all items included
ckjj
