SoundOff HLF or TLF Question
Alex
5
41
Queen Creek, AZ
Alex said:
I just received some of these units and was looking to learn more about them. I've completed a quick google search and have checked SoundOff's website without being able to find any clear diagrams or information as it related to these models.
Thanks in advance for you help!
It's a solid state (as opposed to relay driven) Positive Switched flasher that flashes an alternating constant pattern of 1.9 fps .
Will not work on ground side switched systems.
White - battery 12 volts w/20 amp in-line fuse
Red - to control switch 12 volts to activate flasher
Yellow - to headlight side of cut high beam wire on passenger side
Blue - to vehicle side of cut high beam wire on passengers side
green - ground
black - optional night time cutoff to park light wire or tape and not used
jdarland
