SoundOff Series 400 Question
NOLA26
10
New Orleans
I got a new unit and it has a Soundoff NForce interior light bar with breakout box and a series 400 siren and controller. First I have to say I am not a fan of the SoundOff controller and its programing method. Coming from my old unit and a Whelen HHS2200, I had the horn ring set to the airhorn tone when hands free was not activated. Also when the horn was pressed, the front blue cruise lights activated. Is there a way for me to do this with the Series 400 controller?
The USB port isn't on the handheld controller you're holding. It's on the main siren amplifier unit itself, the large metal or plastic box that all the lightbar and speaker wires connect to, typically mounted under a seat or in the trunk.
You'll need the proprietary SoundOff Signal bluePRINT Link Programming Cable (Part #ENGLNDH002), which connects to a specific 'Programming Port' on that main box. The standard USB-A side goes into your laptop. You can't use a regular phone charging cable.
Upvote 0
dstone
